bkelly Posted May 23, 2008 Share #1 Posted May 23, 2008 The bushings that came with my kit just do not fit...yes I removed the sleeves. I know a lot of people leave these out when they put bushings in because they are a PITA to do. Does anybody have some laying around? Link to comment https://www.classiczcars.com/topic/28213-outer-control-arm-bushings-needed/ Share on other sites More sharing options...
Darrel Posted May 23, 2008 Share #2 Posted May 23, 2008 can you take a pic of your control arm? Link to comment https://www.classiczcars.com/topic/28213-outer-control-arm-bushings-needed/#findComment-248497 Share on other sites More sharing options...
Arne Posted May 23, 2008 Share #3 Posted May 23, 2008 New rubber bushings are available from your Nissan dealer in fairly short order. Part number is 55541-E4100. Link to comment https://www.classiczcars.com/topic/28213-outer-control-arm-bushings-needed/#findComment-248503 Share on other sites More sharing options...
bkelly Posted May 23, 2008 Author Share #4 Posted May 23, 2008 This is my problem when I post half awake. I need POLY bushings not the rubber ones. Rubber ones are a last resort. Link to comment https://www.classiczcars.com/topic/28213-outer-control-arm-bushings-needed/#findComment-248533 Share on other sites More sharing options...
beandip Posted May 23, 2008 Share #5 Posted May 23, 2008 What is the problem with the bushings you have not fitting? Are they too long too big around , what? Link to comment https://www.classiczcars.com/topic/28213-outer-control-arm-bushings-needed/#findComment-248544 Share on other sites More sharing options...
bkelly Posted May 23, 2008 Author Share #6 Posted May 23, 2008 They're too big. Yes my sleeves are removed. Link to comment https://www.classiczcars.com/topic/28213-outer-control-arm-bushings-needed/#findComment-248577 Share on other sites More sharing options...
Darrel Posted May 23, 2008 Share #7 Posted May 23, 2008 unless you received the wrong bushings they should fit. 2 sleeves, inner and outer with the rubber between them. Link to comment https://www.classiczcars.com/topic/28213-outer-control-arm-bushings-needed/#findComment-248580 Share on other sites More sharing options...
