Site Updates this Weekend ×
I just bought a 83 280zx the gas gauge read just under a 1/4 of a tank on the little arm gauge, and E on the main gauge. I just put 9 gallons of gas in the car today and it didn't move? Can you fix the gas gauges on these cars? Is there a float in the gas tank? Any help would be helpful. Thanks
https://www.classiczcars.com/topic/28247-gas-gauge/
There are two floats, it is possible that the connections that transmit levels to the gauge are corroded. It is also possible that the electrical connectors are loose, disconnected, or corroded.
While the thread I am about to link to may not relate to your current situation, I have the feeling you will be needing to read it sooner or later...
http://www.classiczcars.com/forums/showthread.php?t=22301
https://www.classiczcars.com/topic/28247-gas-gauge/#findComment-248924
  • Who's Online   3 Members, 0 Anonymous, 635 Guests (See full list)
