Light/combo switch from '77 on '76
Does anyone use a light/combo switch on their 76 from a 77 Datsun? I found a seller, but he is not sure if it will fit mine. What bugs me most with these electrical Datsun deals is how fast the company was changing connectors.
And, will the plastic top/bottom steering column covers for the switch from '77 fit my '76 280z?
Thank you!
Den
https://www.classiczcars.com/topic/28252-lightcombo-switch-from-77-on-76/
We're working on getting all the switches and their build dates documented here... http://www.classiczcars.com/forums/showthread.php?t=30640
Your best bet is to exchange pictures with the guy, and once you get the correct switch, document it on the link above.
Dave.
The part number for the '77 is different than the one for the '76. Doesn't mean it won't work, but it's less likely.
Hey Arne, Can you make the whole list of build dates and numbers available on the combo switch thread that I'm doing (69' to 78'). The pictures help alot but if I had dates on paper to matches switches in cars, that would help a lot.
Dave.
