engine bay refresh..... on a budget
Very very nice! Which Dupli-color paint did you use for the final coat?
I used the Ford Semi-Gloss black and the Chrystler Industrial Red. Both are Duplicolor Colors and readily available at the Auto Parts stores. I can't find the Part numbers online but it should'nt be a problem at the store.
The Red is a hi-temp engine paint and the same color that my cars exterior color was modeled after. I had the paint shop mix it up and brighten it a little with some yellow and orange.
No clear coats, just sprayed on as is.
Dave.
