swapping a 4 speed in to an AT. do i have everything needed?
i've got an AT 77 and the 4 speed is coming off a 78. is this everything i need for a direct bolt in? searched for an hour and couldn't find this exact swap
flywheel/bolts
clutch assembly
spacer plate
tranny
trans shifter and knob
driveshaft
trans mount & bracket
clutch/brake pedal assembly
clutch master/slave cylinders and hardlines
You will need a pilot bearing. Did the tranny come with the necessary linkage for the throwout bearing? You didn't mention either bearing. How about the linkage bushings? That's all I can think of , in additional to what you listed.
Gary
Seems someone told me that, on the 240Z anyway, the wiring harness from the MT won't work on the AT. I can't say from personal experience, cause I haven't swapped to an Auto. Might be worth the investigation. I also know the 240z distributor was dual points on the AT. Can't say why the difference.
He's doing a 77 so it has electronic ignition. Also, he's going AT to manual, not the other way around. No one has mentioned either bypassing or eliminating the nuetral safety switch from the AT but that will have to be done also.
He also has to remove and block off the trans cooler lines to the radiator. I remember doing the neutral switch, but can't remember if it was just connecting the two harness wires together. The last time I did an A to M swap it was 22 years ago, so the details are a bit fuzzy.
You can do either. Connect the two wires together that goes to the switch or unplug the wire that goes to the inhibitor relay and run it directly to the starter. If you do the latter, it will circumvent the potential problem of a bad relay.
  • Who's Online   1 Member, 0 Anonymous, 1,527 Guests (See full list)
