WOT means Wide Open Throttle.
The manifold has to be opened as much as possible to the atmosphere to get all the air it can to do the compression test.
I addition to the points mentioned above, the engine should be at normal operating temperature.
Crank it just long enough for the pressure reading to stabilise.
Make sure you vent the gauge of pressure before doing the next cylinder:cheeky:
