rich280zxt Posted June 12, 2008 Share #1 Posted June 12, 2008 I know this is retarded but I don't want to short anything so I'll make a quick post. How do I put this back together? Its an electronic distributor out of my 240z. The second pic shows the fireball igniton wire and mounting bracket. Where does the little ground wire go? And what hole do I place the mounting bracket in for the cable?? Thanks Link to comment https://www.classiczcars.com/topic/28407-electronic-distributor-how-do-i-put-together/ Share on other sites More sharing options...
Noddle Posted June 18, 2008 Share #2 Posted June 18, 2008 Hi,It doesn't look like anyone on the 240K forum can help you, maybe you could ask in the 240Z section ?Nigel Link to comment https://www.classiczcars.com/topic/28407-electronic-distributor-how-do-i-put-together/#findComment-251205 Share on other sites More sharing options...
