i have a 240z and there is a metal on metal noise coming from the left rear.
the noise only happens every half spin of tire. e brake is very week so i don't think it is it. does anybody have a clue before i go tearing away at it.
also there is a clicking noise coming from the right side of the rearend. this noise only starts at 35 mph and varies from rpms. if no gas if being pushed at 60 then it rides smooth enought but when accelerting a bad wobble comes in and a clicking noise happens. if any body has any answers it would be greatly appreciated.
roby 240 thanks
https://www.classiczcars.com/topic/28462-left-rear-brake-noixe/
Roby, the brake noise could be any number of things, the best thing to do is to pull the drum and take a look.
The other noise and vibration sounds like one or more bad u-joints. You car has 6 u-joints, 2 in the drive shaft, and also 2 in each halfshaft. I suspect a bad one in the right halfshaft.
