I have a drill press too :)
Then just drill out the sheared bolt and press in a new bolt.
I'm not sure about which years are applicable. Some sources say that you need a '75-'78 280z booster, other places say that '73 and up will work.
The automatic transmission 280z has a larger (10") booster that won't fit into a standard transmission equipped 280z - I think that the larger booster bumps into the clutch master cylinder.
Pull your '73 or '74 booster and see if its firewall bolts line up to the holes in the firewall - the bolts on the earlier 240z's are closer than the the bolts on the 280z's.
By the way, prepare to cuss as you're removing the nuts under the dash that hold the booster to the firewall - it's pretty tight on two of the bolts and scrapped knuckles are common.
https://www.classiczcars.com/topic/28465-doh-i-broke-it/#findComment-251185
The dash is out of the car already :)
https://www.classiczcars.com/topic/28465-doh-i-broke-it/#findComment-251191
