Unlikey but you could always do something like, drain the diff oil and refill, drive it and listen for the clunk.
Clunk is normally attributed to either a faulty diff mount insulator, arrestor strap, half shaft or drive shaft universal joint and or a combination of all.
https://www.classiczcars.com/topic/28484-my-differential/#findComment-251312
U-joints are pretty easy to change. With shop rates near $100./hour do you really want to find out? :) You need a few basic tools and it would cost less than paying a shop. (Hammer, socket, snap ring pliers and two 12mm wrenches) To be safe I always use red loctite on the driveshaft bolts when reassembling.
Check for loose mounting harware by tightening all harware related to the diff. Two common culprits are the mustach bar outer and inner nuts.
2c
Jim
https://www.classiczcars.com/topic/28484-my-differential/#findComment-251409
  • Who's Online   1 Member, 0 Anonymous, 1,493 Guests (See full list)
