The pump is mechanical, not electric. .
On some later 240's they had an additional electric pump near the tank IIRC. I don't know if failure of the electric pump could restrict the mechanical pump from getting gas. (If you have a two pump system) The electric pump is near the tank.
I've had mechanical pumps which seemed fine but needed to be replaced. It wouldn't hurt to have a spare and they're $40 at autozone. Valve cover gaskets aren't that expensive so I'd just take the cover off and see. I'd pop the cover off and use a screwdriver to bypass/switch the starter on. This will allow you to see if the eccentric cam working. Turn the engine over with the pump installed and valve cover off to verify motion if a replacement pump doesn't fix it.
A clogged fuel rail can also cause a no flow condition. I've posted my experiences with a clogged fuel rail so a search might help.
Do these things and it WILL live again! :) :)
In synopsis...
1 Add 2 gallons gas. It's a simple thing to overlook
1a.Try manually drawing fuel to verify flow. (See previous JimmyZ post)
2.If fuel flow exists replace filter. Make sure that all hoses fit well and have good clamps.
3.Fill float bowls manually
4. Crank and run engine for 45 seconds if no fuel is pumped/drawn replace pump.
5. Fill bowls again and start engine. If new pump fails to produce fuel check eccentric. Also check for flow with exit end of pump unplugged.
6 If pump flows on engine (When turning) then the fuel rail/carb strainers are suspect.
7. Clean rail and float bowl strainers. There are posts detailing good ways to clean the rail.
Just trying to help.
Jim
Just did a search one the fuel pump topic. Check out Carl Beck's post. This cleared up the electric pump issue.
http://www.classiczcars.com/forums/showthread.php?t=29392&highlight=240z+electric+pump
There was also an extra filter described in back. The good news is that the electric pump is an aid and the car can function w/o it.
Excellent suggestion, I thought this was an issue, so I added 4 gallons. I'll check this one off!
Have not done this yet.
Haven't drawn it manually, but there's no fuel flow to the carbs, so I've "skipped" this stage. Strangely, fuel is present in the filter.
Did this - and #4 happened
Removed pump, checked everything - still think this is the culprit (which you mentioned having an extra). I am sort of at this stage
This will be next - although I did clean out the float bowls...they were pretty clean for a 35 year old car!
It's much appreciated - to everyone! I misunderstood your part about the secondary, electric pump...I probably should check that, but as you mentioned the car can function w/o it.
So I think the next step is to take the inspection cover off of the fuel pump and start the car to see that the valves are opening/closing. I do know the pump rocker arm is up against the eccentric, I checked that when I re-attached it.
Rich
Did you check the fuel rail idea ?
I had a clogged return line on my 240 that acted like this....
Jay
zdisease
I have not checked the rails. I mentioned that my float bowls are very clean, no sediment at all. I did notice some sediment in the pump, but nothing major. I surmise that a clog would result in poor running before complete stall, and the car never acted weird - it just stopped like it ran out of gas.
Per JimmyZ's suggestion, I'll work my way towards the rail - I am still stuck at the fuel pump!
  • 1 month later...
I did check to see if the mechanical pump was working (ran hose to a can) - it looks like that's the issue.
Someone suggested AutoZone - they have an "Airtex Master" fuel pump that apparently fits. Looks much different from the OEM unit, but at $37.99, it's much better priced than what's at Black Dragon.
Anyone have experience with "Airtex Master" and/or AutoZone?
