early Z rear brake conversion
Anyone out there familiar with a rear disc brake conversion for an early Z (280-Z ) race car that utilizes a 240/280 Z front caliper which uses a `spacer` to split the caliper halves to gain 3/4" in width which then slip over a 1" wide 11" dia vented rotor? This is what is on my vintage 280Z race car. It has a nice hub mounted bolt-on caliper bracket ......... I`d like to duplicate this set-up. This car came from the SE part of the country many years ago.
Any info on this set-up would be appreciated.
Jeff Winter Rallye/Sport - Winter Racing Engines 303 427 0510
https://www.classiczcars.com/topic/28522-early-z-rear-brake-conversion/
Jeff,
Sam can make these. It utilizes a homemade spacer and the stock o rings I believe. The spacer size depends on the type of rotor you choose. The reason I know about this is because we once thought the stock 240Z front brake set up would be more efficient than the zx option we are allowed due to the rotor (solid) being larger in diameter.
Greg Ira
  • Who's Online   1 Member, 0 Anonymous, 1,292 Guests (See full list)
