Ok so here I go again.
The tranny is out of a 10/71, It has bad play in the shifter. Before I put it in the car I am replacing the shims and bushings. But I don't know witch kit to buy.
I looked all over the trans for a part # and cannot find one. The only letter/number I can find is an L-2 casted into the side of the trans.
What type trans is this?
https://www.classiczcars.com/topic/28538-tranns-type-question/
Try this out Bill.
http://classiczcars.com/forums/showthread.php?t=22132&highlight=shifter+bushing
I was doing the same thing a while ago.
Don't use the door bushing kit from other sites, it does not work for very long. When you replace the bushings in use a little lithium grease all over the area to keep friction down when shifing. I would think brass would be the way to go.
I've tried brass a couple of times over the years in various Datsuns. My conclusion: Properly installed and lubed OEM nylon lasts a long time and doesn't create the vibration that brass does. That's the main reason they use nylon instead of some kind of metal. If the vibration doesn't bother you, then use brass. They still wear but not as fast.
Make sure you know which tranny you have, does it have linkage exposed or does the shifter go into the tranny?
The door hinge bushings work for the later transmissions that have the lever going into the tranny.
The linkage is inside the trans
If it is like this, then the hinge bushings are the most economical way to replace if you have a bench vise.
http://www.classiczcars.com/photopost/data/500/medium/4_spd.jpg
If any filing needs to be done it might need to be dome on the flats after the bushings are pressed in to fit between the ears. Using the bench vise you can press them in square one bushing at a time, then use the vise to again press the pin through the bushings, this will form the bushings to the pin for an exact fit. It might be a little tight at first but twisting it back and forth will free it up easily.
I have used my shifter on the track and put it through it's paces for over 6 yrs and have not had a problem. It's still as tight and no wear.
help me part # 38377 for the pair of bushings. There is another bushing variety pack that has 4 sets of different bushings, one set maybe two will work, not sure of the part number on that, but same section in "help me". Either set is less than $5.
  • Who's Online   2 Members, 0 Anonymous, 1,292 Guests (See full list)
