This drivers side door-jam area trim piece i need to get replaced. Basically it is on the bottom of the door jam; between the carpet and the metal plate/rubber seal (in the door jam) --- It has interior material on it, although metal underneath. I'm curious what this trim is called.
The piece I currently have was rusted out so I removed it. Any idea where I can get it replaced?
I can post a photo of the actual trim later on, although i think you guys get the point...
Thanks!
https://www.classiczcars.com/topic/28562-help-identifying-this-panel/
Thanks for identifying them!
This site sells them:
http://www.auto-body-part.net/Rocker_panel.htm
Listing: 167-70-40-LH Rocker 70-78 $69.03
A bit expensive. $69 just for that small panel.
Better off searching craigslist or various parts cars.
I think he is asking about the interior trim piece that sits on top of the rock panel, and I believe that is called a scuff plate. I only have 240Zs, but I assume it is a similar piece on 280Zs. If you get the parts CD from the club and can get the part numbers you will need to order replacement parts from the dealer.
-Mike
That isn't the rocker panel, the rocker panel is what is BELOW the piece you removed and underneath that aluminum trim piece on the outside with DATSUN embossed on it.
The piece you have removed that pinches the carpet to the rocker panel is called a Scuff Plate. These are typically metal with a vinyl covering. The Vinyl will have the same embossing as the rest of the interior.
Not sure if Black Dragon or MSA will have them, but it's worth checking.
FWIW
E
Thanks for setting me straight, fellas!
And Stephan, thanks for that (again)!
Honestly, I thought the scuff plate was the stamped "L" shaped aluminum piece on the outboard edge of the sill. What's that thing called then?
  • Who's Online   1 Member, 0 Anonymous, 1,537 Guests (See full list)
