Center Console Damage (Fixable?)
I have some damage to my Center Console...It isn't THAT bad, but I am trying to restore the car as best as I can. I know buying a replacement is the obvious solution, but they are pretty expensive (200 - 300/for the 1975 console)
Can cracks in the plastic be fixed anyway? DIY fashion?
Any ideas? (I can uploaded photos if you need to see the damage)
https://www.classiczcars.com/topic/28721-center-console-damage-fixable/
I had a crack in mine about 1-1/2" long that started at the ashtray opening. I scuffed it up and used JB Weld on the backside and it has held well. There is a tiny hairline showing on the top, but you have to be looking for it to see it. You could probably strengthen it more by adding a piece of cloth in the epoxy.
I remember following a link on here quite awhile ago from someone that fixed a dash very impressively. I found the link and here it is...
http://www.classiczcars.com/forums/showthread.php?t=23919&highlight=dash+repair
Maybe you can incoporate some of his process into your console repair?
Funny you posted that, because I was just reading that post LOL
I'm actually going to purchase the materials tomorrow to redo my dash, the same way. I have about 3 minor cracks in the dash that I would like to address, without spending hundreds on a new dash.
