So here it is, fuel injected SU
I mounted 1 GM injectors in both SU. I have a GM ECU that's monitoring sensors for MAP, TPS, Water, LAMBADABADA, and Coil. The thing is 100% stealth for the novice I think. My idea is to have the standard looking car but with the driveability of a modern car, good gas mileage or crazy Mapping for the track...
Lot of tuning to do but it is running very strong until the battery drains out!!!!
et voilà
https://www.classiczcars.com/topic/28729-fi-su-backt-to-the-future/
No but you could, it's a GM ECU with a std map, I need to collect data to burn a new one.
My engine is an L28 with a fast/road cam on a P90 1mm milled head with an old Thunderbird full line exhaust... 6/2/1 --- dynomax ---- 2 twice pipes
It wouldn't be fair to claim paternity for this setup. I had the idea for a long time and discuss it with Rick at http://pattonmachine.com/
I was in fact developping the same setup for 3 downdrafts and made a pose
to try this path with Rick. Once runing and dynoed I will resume the first project!
He is an awesome man and truly crafted! We have been exchanging for more than 6 month on this and I think he will make a batch of them if you want to.
  • Who's Online   1 Member, 0 Anonymous, 1,134 Guests (See full list)
