Does anybody have pictures of tokiko springs installed on the front of their Z. I was checking mine out on my recently purchased 71, and when the car sits at rest it looks as if the coils are almost binding. IF this is true then the car uses its bumpstop for almost its entire suspension...
Now all I saw was the top portion of the sping, which may or may not have been progressive, so I may have more coils below the tire I could not see. I noticed this as I was waxing my rocker panels the other day. Just thought I would ask.
THanks!
https://www.classiczcars.com/topic/28808-tokiko-springs-installed/
That's normal for the tokicos. The progressives go with the close coils to the top. Although I'm not sure if it would make a difference. The fronts are progressive and the rear are linear.
The progressives are used as your'e going over small bumps to soften the ride.
  • Who's Online   2 Members, 0 Anonymous, 406 Guests (See full list)
