Hi Guys,
been trying to update the website a little, but here are some updates to the project :)
Things done so far:
replaced Belts, idler and tensioner bearings, water pump
Installed R33 RB26DETT N1 Camshafts
removed Front Diff from sump, cut up to clear the 240K, and had the hole rewelded in Aluminimum
Installed Trust sump baffle (had to trim to fit)
Removed the intake plenum, Cam covers, front covers and top turbo pipe for Powdercoating
general clean up (including cleaning up the individual throttle bodies)
Bolt up RB25 5 Speed Gearbox
waiting for an ATI balancer and HKS adjustable cam gears to turn up
here are a few pics (and a hint as to the colour scheme of the engine, which i can hopefully reveal next weekend)
https://www.classiczcars.com/topic/28900-rb26-updates/
not really chasing anthing more than the standard output at this point ( though the thought of a set or GT-SS's have crossed my mind :)).once the car is done and registered it will be another story ;)
As if your not chasing more than the standard output!... if you we're you wouldn't have bothered with the N1 cams and adjustable hks equipment :tapemouth
https://www.classiczcars.com/topic/28900-rb26-updates/#findComment-255360
purely oportunistic :)
i bought the N1 camshafts with a set of N1 rods, as i was planning to build up an N1 block before i found my RB.. so with the cam covers off.. i may as well throw the camshafts in! (and who wouldn't for $200 for a set of cams :) ) same goes for the cam gears, since the timing belt is off, may as well throw a set in (so it can be tuned properly later on.. will be running the std ECU until the car is "complete")
https://www.classiczcars.com/topic/28900-rb26-updates/#findComment-255385
  • 1 month later...
Unfortunately it is taking me a lot longer than expected to get the engine covers painted :(
My powdercoater originally had trouble matching the colour on all the panels, then his gun broke.. hopefully next weekend i will get them back and be able to show it off :)
on a happier note, i successfully repaired my crushed ECU plug with one off a spare RB25DET loom (the connectors are the same)
here's a bit of a teaser
Edited by khughes
https://www.classiczcars.com/topic/28900-rb26-updates/#findComment-261100
  • 3 weeks later...
here's the inspiration..
speaking of which.. does anyone know why some S20's have red cam covers as oppose to grey/
Kent,
No S20 engine left the factory with a red cam cover. Stock colour on the C10 and C110 GT-Rs, and the 432 and 432-R model Fairlady Zs was a crackle-effect in very dark grey ( with an almost greenish tint ).
Factory 'works' race S20 engines had magnesium ( as opposed to aluminium alloy ) cam covers with the extra spark plug lead retainer rings, and were usually painted straight matt black without the crackle finish.
The only reason you will occasionally see red painted ones is because the owners, or some specialist workshops like Ishikawa's, painted them like that later on. Watch out for false data that tells you the works ones were red or green ( did I read this on Wikipedia once? ) which is a load of bollocks.......... :)
https://www.classiczcars.com/topic/28900-rb26-updates/#findComment-263588
nice, thanks for that.. i always guessed that they must have changed the colour on later engines.. and now i know :)
my engine was powdercoated in a wrinkle finish, but not to the dark grey level where it is greenish (it is hard to see from photo's), but i am happy with the way it turned out :)
of course.. it isn't an S20, now that would be something! :) what is the engine like? is it revvy? low end grunty? lumpy? how does it compare to a mildly worked L28?
https://www.classiczcars.com/topic/28900-rb26-updates/#findComment-263590
