Okay so im trying to install a Crane XR3000 into my late 260Z and from what I read I need to bypass the ballast resistor. Everything ive found says just run a jumper wire to the two wires on the resistor, but I have three wires on my resistor (the PO did a hack job with the ignition). Can anyone tell me how to bypass my resistor?
Thanks
Brad
https://www.classiczcars.com/topic/28928-bypassing-the-ballast-resistor/
It looks to me like take the far right wire off it's terminal and connect it to the far left wire terminal. But I'm not that familiar with those so I think I'd wait for one of our experts to chime in. How are things in Tucson? That was my old stomping grounds for 30 years.
Steve
Well im not sure about just moving the left wire to the right wire, first of all the left wire has a positive sign next to it and the right one has a negative sign next to it, and connecting a "+" and a "-" doesn't seem like a good idea and second what do i do with the middle wire?
The plus side will be battery voltage the negative side has the voltage lowered by the resistor and goes to the coil. By connecting those two together as I proposed you no longer drop the voltage to the coil. AKA bypass the resistor. I would guess that the middle wire has it's voltage dropped by a lesser amount and goes somewhere else. I would leave it alone. Again I'm using general automotive knowledge and not Z specific so I could be missing something.
Steve
