If you coat the fins with paint , it will impede the heat transfer and the radiator will be less efficient. This is the reason you only see a vary thin coating on the grid. On the tanks and frame , '' knock your self out''. LOL do what ever.
Gary
  • 1 month later...
They make a super high emmisivity paint for solar hot water panels which would actually improve the heat rejection of the radiator. Any color you want as long as it's flat black.
Enz
That increases the radiant heat transfer but slows the convection heat transfer rate. Since it's primarily the convection rate (the majority of the fin's surface area faces other fins so they emit and absorb to and from each other) that's more important. On the tanks it would be a plus as they are not in the primary airflow and their surfaces don't face each other. That's splitting hairs in reality though.
Steve
