VG30 engine config? Need info ASAP
Hey gang, I know this is not an L6 question, but I know many of you have newer Nissans too. I need to know where cylinder #1 is located in a VG30 engine. My aunt's Infiniti I30 has a bad O2. Autozone's scan revealed O2 #2 in bank #1 is the culprit, but she lives 200 miles away, so I can't open the hood to see what the engine layout is. :stupid: Each sensor is different, so I need to tell her which one to buy. The stealer wants $500 to replace one sensor, so she might buy the part and find a local mechanic to install it.
https://www.classiczcars.com/topic/29473-vg30-engine-config-need-info-asap/
