Turn signals/hazard lights
I have a 71 240 Z (71/5). I replaced the dash wiring harness and have trouble with the turn signals and the hazard lights. The hazard flasher lights do not work. The turn signals only work if I turn the hazard switch to the on position. I have replaced the flasher. I don't hear the click when I turn the flasher switch to the on position. It seems also that the brake lights do not work. Any help is greatly appreciated.
Lewis
https://www.classiczcars.com/topic/29514-turn-signalshazard-lights/
Start checking the wiring around your Turn signal switch. The brake lights, turn signals and flasher wires go thru the T/S switch and associated wiring.
also make sure that the Flasher unit is connected correctly, there is only 2 wires so it should be an easy swap and check. Check the wires of the Hazard switch, the body of that switch is fair game to gremlins.
  • 4 weeks later...
  • Who's Online   2 Members, 0 Anonymous, 1,345 Guests (See full list)
