Curtis240Z Posted October 15, 2008 Share #13 Posted October 15, 2008 WOW! Thanks for the info.260HP was with triple Weber dcoe45 (Italy version) but I don't think I'm gonna keep these since I'm not familiar enough with carbs. This is a for a week end car. Not for racing. If I stay with my SU, would I loose a lot of HP?For your info, the motor is a L28 (don't know which one.... the vin have dissapear on the lock), E88 port and polish head with bigger valve, Racing springs, Cifford SS headers with Dual pipe, Perfomance ignition, don't know the spec of the cam. Racing oil pump, 7qt baffle oilpan, Oil cooler, ect.. The car was running on standard 94 octane gas. So don't the compression is too high for street use.Thanks for you help,JoceHave you driven it on the street yet? While you would lose some bottom end with the big carbs, it still maybe streetable depending mostly on the cam. Many owners run around with 45 mm DCOE carbs on the street. I am running 45 DCOE throttle bodies and it is quite streetable, not to mention the rush when you get ON IT! Link to comment https://www.classiczcars.com/topic/29645-bob-sharp-racing-parts-catalogue/?page=2#findComment-263359 Share on other sites More sharing options...
jcote75 Posted October 16, 2008 Author Share #14 Posted October 16, 2008 no haven't run them yet.I would really like to keep those carbs on but I've been hearing that they need some ajustment depending ot the weather. Here in Quebec, we have all kind of waether all year long.Also heard that it need ajustment almost every week to keep it perfect tunedAlso heard that gas can spill out on hard turn with no gas? It have a huge ugly plate underneath to avoid gas going on the headers.Are these all true? And how hard it is to do the maintenance tuning on them?Thanks in advance,Joce Link to comment https://www.classiczcars.com/topic/29645-bob-sharp-racing-parts-catalogue/?page=2#findComment-263513 Share on other sites More sharing options...
ToXIc Posted October 16, 2008 Share #15 Posted October 16, 2008 J.... enough with the teasing..... pics!!! pics!!! :embarrass: Link to comment https://www.classiczcars.com/topic/29645-bob-sharp-racing-parts-catalogue/?page=2#findComment-263514 Share on other sites More sharing options...
d240zx2 Posted October 17, 2008 Share #16 Posted October 17, 2008 no haven't run them yet.I would really like to keep those carbs on but I've been hearing that they need some ajustment depending ot the weather. Here in Quebec, we have all kind of waether all year long. Also heard that it need ajustment almost every week to keep it perfect tuned Also heard that gas can spill out on hard turn with no gas? It have a huge ugly plate underneath to avoid gas going on the headers. Are these all true? And how hard it is to do the maintenance tuning on them? Thanks in advance, Joce Your Webers are similar to Mikuni units. My 40mm Mikunis are a set and forget carb, unless you change altitude drastically. No problem with fuel spillage, although they can and do drip a bit on start-up sometimes. I'd say keep 'em. They're good units and will give you a turbo-like rush when your right foot gets heavy..... Frank Link to comment https://www.classiczcars.com/topic/29645-bob-sharp-racing-parts-catalogue/?page=2#findComment-263556 Share on other sites More sharing options...
Curtis240Z Posted October 17, 2008 Share #17 Posted October 17, 2008 I concur with Frank, only big altitude changes really affect jetting. Gas does not spill out in turns if the fuel bowl levels are correct. There should be a heat shield between the carbs and header to prevent heat soak. Link to comment https://www.classiczcars.com/topic/29645-bob-sharp-racing-parts-catalogue/?page=2#findComment-263584 Share on other sites More sharing options...
