ramsesosirus Posted October 18, 2008 Share #1 Posted October 18, 2008 I have a manual pull/push lever on the passenger side of my 76 280Z, under the glovebox. What does this do? is it stock? I've seen pics of them next to the fuse box but mine is more under the glove box.Thanks. Link to comment https://www.classiczcars.com/topic/29700-pull-lever-by-fusebox/ Share on other sites More sharing options...
EScanlon Posted October 18, 2008 Share #2 Posted October 18, 2008 Fresh Air Vent. (Tell your date that it's the release handle for the side access door up by the hood and see if she doesn't pull on it.... ) Why you would equate that with the Choke Lever or the Heater Controls -- I don't know. Then again, it may be that you saw a Fresh Air Vent knob by the fuse box... which gives rise to other questions.... FWIW E Link to comment https://www.classiczcars.com/topic/29700-pull-lever-by-fusebox/#findComment-263696 Share on other sites More sharing options...
DougN Posted October 19, 2008 Share #3 Posted October 19, 2008 You should have one on the drivers side in the same location as well! Link to comment https://www.classiczcars.com/topic/29700-pull-lever-by-fusebox/#findComment-263727 Share on other sites More sharing options...
ramsesosirus Posted October 21, 2008 Author Share #4 Posted October 21, 2008 Thanks; I equated it to a choke lever bc that is exactly what they look like on old Jeeps and on the golf carts at work. I'll have to check the drivers side for one as well. That just shows how young I am, any car I've had has the fresh air selector on the HVAC controls. So which setting is for fresh air? Link to comment https://www.classiczcars.com/topic/29700-pull-lever-by-fusebox/#findComment-263927 Share on other sites More sharing options...
Mr Camouflage Posted October 21, 2008 Share #5 Posted October 21, 2008 Pull it out for fresh air. Link to comment https://www.classiczcars.com/topic/29700-pull-lever-by-fusebox/#findComment-263928 Share on other sites More sharing options...
