Well I have received my second tranny mount for my 7/71 240Z. And again it will not bolt up. The problem is the same. On my mount that I removed, if you draw a line in between the bolt holes that go to the transmission, the threaded bolt that sticks down to attach to the cross member is directly in line.
On Both my mounts I received from Black Dragon, the threaded bolt for the cross member is a 1/4" up. No amount of forcing, cussing, or beating will make it go in this way. The Mount is just not right.
I guess I will try MSA, but if they use the same vendor, then I am hosed.
I have a new Nissan diff mount, so I wonder if Nissan Dealers would carry a tranny mount?
Black Dragon Mount:
Old Mount:
Here is my car waiting for a new mount!
https://www.classiczcars.com/topic/29705-transmission-mount-issue/
Interestingly, the rear transmission mount in mine is one of the very few parts that I have bought from BD, part number #62-700. I've had that mount in my prior yellow 240Z (10/70) and later moved it to the current red 240Z (7/71) when I began parting the yellow car out. It worked(s) fine in both. However, I did buy it from them more than two years ago.
Bear in mind I used that auction only as a picture example. My experience tells me that if that particular eBay seller is selling them as "NOS", what that really means is that you can buy it brand new from your Nissan dealer's parts department, often for less. Plus that seller charges a pile for shipping.
I got mine from Gwinnett Nissan in the Atlanta area. Can't remember the price but they were about 30% cheaper than my local Nissan dealer. They have been great to deal with and have a good internet parts ordering system. The P/N again is 11320-N3200 as Arne previously said.
Thanks, I did get one off ebay, from the seller Arne pointed me to. His shipping is very high (especially since we are both in Houston), but after my refund from Black Dragon, its almost a wash. It has taught me a valuable lesson. Check with this board first, then the dealer second. MSA and BD are great and all, but the factory still supports these cars quite a bit, and I need to take advantage of that.
  • Who's Online   1 Member, 0 Anonymous, 1,431 Guests (See full list)
