Site Updates this Weekend ×
The adjuster lever has a detent pawl on it to prevent the wheel from unwinding and moving the shoes away from the drum.
The FSM says: -
...Remove the clevis pin from the wheel cylinder lever and disconnect the hand brake cable.
...Remove the brake drum adjust hole plug and remove the adjust lever from the adjust wheel with a screwdriver [disengages the detent pawl].
...Turn the adjust wheel downward with a screwdriver to loosen the brake shoe and remove the brake drum.
Additionally, the drum may be siezed on to the cast iron hub but that is another story:surprised
  • Who's Online   1 Member, 0 Anonymous, 632 Guests (See full list)
