Sailor Bob Posted October 31, 2008 Share #13 Posted October 31, 2008 (edited) Did the part numbers chage through the years 79 - 83 ? If so does anyone know what they are? I am poking around and have found a couple of different units (E12-93 for example) - Same? Edited October 31, 2008 by Sailor Bob Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-264959 Share on other sites More sharing options...
sblake01 Posted October 31, 2008 Share #14 Posted October 31, 2008 A quick search shows that there were 12 different part numbers and two alternate part numbers from 79-83 with the NA L28E. I could list them but it probably wouldn't help much without a yearly breakdown. To get that, I'd have to do more research in the Nissan Fast program. Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-264975 Share on other sites More sharing options...
blue 72 Posted October 31, 2008 Share #15 Posted October 31, 2008 The previous owner of my '72 had replaced the dizzy with one from an automatic car (dual points). He had hooked up the yellow temp sensor wire to the distributor for some reason. I was very glad to switch to the ZX dizzy, as the old dual points only let the car rev to 4k. Even with the D6K8 distributor I could only rev to about the 5.5-6k range with the stock head and cam, just remember that those can have an effect on rpm limit as well. Post mods there is no problem going to 8K with the same junkyard sourced dizzy (now it needs a rebuild though).Just for reference, there are a few places on the net that show exactly how to wire in a later distributor in early and late S30's.For instance:http://www.atlanticz.ca/zclub/techtips/distributor/index.htmlhttp://www.datsunzgarage.com/engine/As far as modules go, I have seen only three different (although they may have numerous P/N's). The E12-80 has only the two top prongs, while the E12-92 and E12-93 have two more on the side. I've posted before about how to wire in the E12-92 and E12-93 modules. Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-264995 Share on other sites More sharing options...
Sailor Bob Posted October 31, 2008 Share #16 Posted October 31, 2008 Stephen/Bill - Thanks, that got me running. Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-265005 Share on other sites More sharing options...
sblake01 Posted October 31, 2008 Share #17 Posted October 31, 2008 I meant 12 different distributor part numbers, not module part numbers. Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-265006 Share on other sites More sharing options...
Sailor Bob Posted October 31, 2008 Share #18 Posted October 31, 2008 Figured that out. Thanks anyway Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-265011 Share on other sites More sharing options...
Walter Moore Posted November 1, 2008 Share #19 Posted November 1, 2008 Let's assume for a moment that I live somewhere where 79-80 280zx's are almost non-existent in junk yards... (Which is very close to the truth):nervous:Since I don't have a parts CD for the ZX, is it possible, or worth the effort to buy these parts from some normal, non-used parts source somewhere?What would you expect to pay? I know that most people seem to be able to pull these out of junk yards like strawberries at a berry farm, but some of us don't have that option. Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-265058 Share on other sites More sharing options...
Arne Posted November 1, 2008 Share #20 Posted November 1, 2008 Best bet for you, Walter, would be to buy a reman dizzy from Napa, or Kragen, or whoever you like in that vein. For example, here is the dizzy itself from Napa:http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NRD&PartNumber=48619&Description=Distributor+(Electronic+w%2fo+Module)+-+RemfdThe pros to doing this is that you get one with nice bushings and a rebuilt advance mechanism and such.But there are a couple of downsides. The dizzies bought that way rarely come with modules, and probably never with the mounting tower. The modules can be found on other Nissans in the wrecking yards, lots of early 80's Nissan four cylinders came with the E12-80 too. I've got one I plucked from a 210 wagon, and I've seen them on numerous pickups too. Not sure if the mounting tower was used on anything other than ZXs, though.Maybe some of us out West need to start plucking more of these things and re-selling them to the rest of the country. Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-265063 Share on other sites More sharing options...
a7dz Posted November 1, 2008 Share #21 Posted November 1, 2008 I bought a new dizzy last fall was listed to fit a79 ZX.. It came with the E12-80 module but, I had to get the correct tower separately. Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-265076 Share on other sites More sharing options...
Sailor Bob Posted November 1, 2008 Share #22 Posted November 1, 2008 If anyone has a unit for sale - I am interested. Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-265083 Share on other sites More sharing options...
sblake01 Posted November 1, 2008 Share #23 Posted November 1, 2008 If anyone has a unit for sale - I am interested.PM sent. Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-265085 Share on other sites More sharing options...
Sailor Bob Posted November 1, 2008 Share #24 Posted November 1, 2008 Done! Link to comment https://www.classiczcars.com/topic/29772-zx-dizzy-upgrade/?page=2#findComment-265090 Share on other sites More sharing options...
