you can repalce the alt with 74 260Z and up to 84 maxima's. You will have to switch to an internel volt regulator but there is a plug and play adapter for sale to do that.
Other than that no other modification is needed. Look around the forum by searching
alt upgrade
and you will find many posts and ideas. A direct bolt alt from any L6 series engine will bolt right up just mod the wiring like I said before.
https://www.classiczcars.com/topic/29839-alternator-swap/#findComment-265142
alt upgrade
74-77 were externally regulated and use basically the same alternator as the 70-73 240Z but there were differences in the plug on the voltage regulator depending on the year. 78 and up are internally regulated. Edited by sblake01
https://www.classiczcars.com/topic/29839-alternator-swap/#findComment-265150
