BenyaZ Posted December 7, 2008 Share #1 Posted December 7, 2008 So, i have been reading here for a long time but never really put in my two cents until now. I have a wiring problem that i just can't figure out. My TailLights and Dash Lights are out and i can not get them to come back on. The lights should come on when you turn your headlights on, and my headlights come on perfectly fine but the other lights do not. I have checked every fuse and they are all good. I have also checked all the bulbs to see if maybe they were out and they are still good. My brake lights work fine, but my Taillights and Dash light are the problem. Dose anyone know what the problem could be or could it just be i need to rewire the entire back end?Thanks for anyone's help or comments. Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/ Share on other sites More sharing options...
Sailor Bob Posted December 7, 2008 Share #2 Posted December 7, 2008 Check the fuse box. Later models have these two items on one fuse - probably the same. Go into the search function and type "fusebox" Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/#findComment-268309 Share on other sites More sharing options...
sblake01 Posted December 7, 2008 Share #3 Posted December 7, 2008 (edited) I'm not sure which fuse box a 72 has, console mounted or side panel mounted, but in either case, carefully check the fuse marked 'DOME LAMP-LUZ-INSTRU'. Should be a 10A. Don't just probe it in the fuse box. Take it out and check it making sure that the end caps aren't loose. And make sure that the fuse holders for that fuse are free of corrosion, etc. Edited December 7, 2008 by sblake01 Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/#findComment-268311 Share on other sites More sharing options...
Sailor Bob Posted December 7, 2008 Share #4 Posted December 7, 2008 This one ? (GreenZZZ's photo) Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/#findComment-268312 Share on other sites More sharing options...
Zs-ondabrain Posted December 7, 2008 Share #5 Posted December 7, 2008 (edited) Pull the steering column coverCheck the green/white and green/blue wires on the switch, for power.Your wires are either burnt or the contacts are burnt.Use a volt meter to see if you're getting power from the fusebox. If you do, check the switch to see if that power is getting to the other wire. If it's not, the switch needs to be rebuilt.Dave. Edited December 7, 2008 by Zs-ondabrain Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/#findComment-268327 Share on other sites More sharing options...
Sailor Bob Posted December 7, 2008 Share #6 Posted December 7, 2008 Don't you think it would be better to just check the fuse first. Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/#findComment-268333 Share on other sites More sharing options...
z74z90 Posted December 7, 2008 Share #7 Posted December 7, 2008 And really "check". They can have a almost invisable hairline crack.They don't have to be obviously burned and blown. Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/#findComment-268335 Share on other sites More sharing options...
BenyaZ Posted December 8, 2008 Author Share #8 Posted December 8, 2008 I checked all the fuses, pulled them out, tested and put them all back. All of them were working fine. I have the Console mounted fuse box. But i didn't have time to pull apart the steering column so i will check the wiring in there tomorrow after work. Thanks or all the help and suggestions. Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/#findComment-268346 Share on other sites More sharing options...
Grif260z Posted December 13, 2008 Share #9 Posted December 13, 2008 From experience on my 1972, sometimes the fuse block goes bad on the back of the fuse block, also check your grounds on the tail lights, My Fuse block melted on the back Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/#findComment-268850 Share on other sites More sharing options...
reddie73 Posted December 18, 2008 Share #10 Posted December 18, 2008 I agree with grif260z. My 71 had melted from the back side and I got epoxy glue and filled in around the back where the wire was and the fuse holder is stable now and works fine. I also pulled a console and fuse box from a wrecking yard 72 and the same thing on that fuse box, melted on the back side. Doesn't sound like a ground if the taillights are working, but I would check it anyway. Link to comment https://www.classiczcars.com/topic/30174-help-tail-lights-out-1972-240z/#findComment-269143 Share on other sites More sharing options...
