Dupli-color interior paint = TERRIBLE!
I didn't use any primer either.
I've also worked with a local guy recently that restores interiors on Rolls Royces, and all we did before dying the leather was to clean it- with a special solvent/cleaner. Then the dye was sprayed directly on. He told me that painting/dying vinyl or plastic parts was the same.
I gotta agree that you can't clean the part enough before painting. Any residue from anything will produce inferior results, And the newer sprays are the toughest to remove completely, which is why they work so well.
Tim-
Can you elaborate on why you suggested using primer? What kind of primer?
thxZ
Edited by TomoHawk
The laquer thinner worked better than anything else I tried. All of the plastic and vinyl had 26 year old overspray primer every where. Just took lots of time cleaning small areas at a time and not getting it too wet and changing cloths often. Just make sure there is no way for combustion and plenty of ventliation so you won't get as HIGH as I did the first half hour.
Bonzi Lon
  • Who's Online   2 Members, 0 Anonymous, 1,421 Guests (See full list)
