kully 560 Posted December 30, 2008 Share #1 Posted December 30, 2008 hello everbody I have owned my early 260 z for 29 years fully restored.1983 zx motor and 1971 4 bolt round tops su carbs. I just joint this site, looks like a good forum my name is kully. I been looking for some help ,I installed a new 1979 zx dissy and can not get my tach working. tried some resistors of different values but tach seems to jump around at idle and at high rpms works ok but when I slow down it jumps around. can anybody help with a solution thank you kully Link to comment https://www.classiczcars.com/topic/30362-tach-hook-up-zx-dissy/ Share on other sites More sharing options...
Zs-ondabrain Posted December 30, 2008 Share #2 Posted December 30, 2008 on a 240Z, you bypass the Ballast resistor. But if the tach is jumping around on a 240Z after that process, the tach is probably bad.If you have the 3 pole ballast resistor, run a jumper on the end bolts, not the middle one. if the tach still jumps around, you might need another one.FWIW,Dave. Link to comment https://www.classiczcars.com/topic/30362-tach-hook-up-zx-dissy/#findComment-269860 Share on other sites More sharing options...
beandip Posted December 30, 2008 Share #3 Posted December 30, 2008 (edited) If you are Edited December 30, 2008 by beandip Link to comment https://www.classiczcars.com/topic/30362-tach-hook-up-zx-dissy/#findComment-269869 Share on other sites More sharing options...
beandip Posted December 30, 2008 Share #4 Posted December 30, 2008 If you are using the '79zx dist with the '79 coil you do not use the ballast resister . this is the set up I am running also. Link to comment https://www.classiczcars.com/topic/30362-tach-hook-up-zx-dissy/#findComment-269870 Share on other sites More sharing options...
kully 560 Posted December 30, 2008 Author Share #5 Posted December 30, 2008 I am not running the ballast resistor I took the blue wire from the tack and hooked it up to the neg. side of the coil and tried some resistors . tach works fine with orignal 74 daul pickup dissy got to be some way to get the tach working Link to comment https://www.classiczcars.com/topic/30362-tach-hook-up-zx-dissy/#findComment-269873 Share on other sites More sharing options...
