Series 1 Engine Paint Plan - Details Please
I plan on painting mine black this week. Maybe you were talking to Wally. I think somebody said "satin black".
Actually, it was based on the two pictures you attached in post #66 above. Why paint it blue with the block if you are going to paint it black this week?
-Mike
-Mike
Sorry, I should have been clearer. I left the oil pan on when I painted the block so I wouldnt have to mask it off. The PO had it painted blue. I have all intentions of painting it black, hopefully this week.
Edited by JohnnyO
I used Duplicolor DE 1631 Chrysler Blue. Its the closest color I could find in a pre-mixed rattle can.
OK. I was beginning to worry that I got the wrong color from Tower. It does look closer than Old Ford Blue.
Thanks Mike and Jonny'O, I'll repaint the oil pan , and relook at timing cover and oil pump and compare every thingelse with the previous posts on original engine colors. What a large number of differences. Thanks for all the help. I'll be asking for more as the project continues to completion. This is the first 240Z restoration for the guy doing the job, see his site at RodShopOfMemphis.com
Wally
So here are the details as I have learned over the last few weeks. Pictures of what I have done will be added soon.
Block: Datsun "Dusty" Blue
Oil Pan: Black; Satin or Semi-Gloss (not positive yet)
Crank Pulley: Blue
Smog Pump Pulley: Blue
Smog Pump Casing: Natural
Smog Pump Rear Plate: Black
Timing Cover: Natural
Water Pump: Natural
Alternator Casing: Natural
Alternator Fan: Cad Plated
Alternator Pulley: Black
Cam Cover: Natural
Head: Natural
Misc. Water Pipes: Cad Plated
Water Inlet/Outlet: Natural
Oil Pump: Natural
Distributor: Natural
Thermostat Housing: Natural
Air Box: Orange
Fuel Rail: Cad Plated
Carb Linkage: Cad Plated
Motor Mounting Brackets: Black
End Plate/Bell Housing Cover Plate: Silver Zinc Plated
Intake Manifold: Natural
Exhaust Manifold: Natural
Alternator/Smog Pump Adjusting Arms: Blue
Cooling Fan: Off-White or Antique White
Cooling Fan Clutch: Natural
Cooling Fan Pulley: Cad Plated
If you see any thing that needs correcting or if I missed a part please let me know.
When I say natural I am essentially talking about a good glass beading job. You can add a coat of flat aluminum as suggested above on all but the head I would imagine.
Still don't know the exact color for the Orange airbox. I tried VHT Orange header paint and I just don't like how it covers. I have used 3 cans and it still needs more. Plus you have to clear coat it after baking.... I may contact Tower Paint to see if they have it.
Well, I hope this helps anybody that stumbles upon it.
Edited by JohnnyO
Added parts that were missing; corrected items. 2/11/09
John,
The oil pan, to be totally correct I believe, should be a semi gloss to gloss black. The alternator fan is gold cad, as you mentioned, but the alternator pulley
should be semi-gloss black and the securing nut and washer in the center should be gold cad. This can be seen in the early maintenance manuals that I have. Opinion about the pulley color has been mixed in difference discussions here, but this is my conclusion, FWIW.
Dan
The bell housing cover plate, or as I call it 'end plate", is steel and is plated. I think silver zink however I see them in light gold cad. I agree with Dan in that 'satin black' could be 'semi-gloss'. The old paint I look at on my parts has some sheen to it. That could be the age as well as the scrubbing to get the part clean. I went with semi-gloss. My alternator pulleys are black with the light gold cad fan. The shop manual shows it that way even though it is a B&W photo. The pulley is solid black in the exploded diagram also. FWIW
Original cad plating, as we call it gold cad, isn't very gold and isn't a consistant color. I have seen restored stuff that is jewlery-store gold in color and that's not completely correct. Have a look at the pulley bolt picture I posted. It almost looks silver.
Someone maybe it was Chris said that we sell Tower Paint but I do not we make and sell our own Mix on all our paints custom made for us by Sherwin Williams and where needed the correct additives added for heat or flex or flattening the color to get them right. May cost a little more but the quality of real automotive paint sure beats the cheap bomb cans in most cases. never had any complaints on our engine paint nor air cleaner paints. Take care!
Les
Les
Thanks for letting us know. I don't think anyone here doubts the quality of ANY of your products. You and your company come highly regarded.
John
  • Who's Online   0 Members, 0 Anonymous, 844 Guests (See full list)
