refman1970 Posted January 6, 2009 Share #1 Posted January 6, 2009 I have a 1978 280z with an issue with the passenger headlight is dim and the dash lights and tail lights do not work I have checked the bulbs and fuse block and still not lights any ideas? Link to comment https://www.classiczcars.com/topic/30441-lights-out/ Share on other sites More sharing options...
d240zx2 Posted January 7, 2009 Share #2 Posted January 7, 2009 Have you replaced the fuses? They can look good (unblown) but still will not pass current. Test each one with an ohm meter and clean off all corrosion on the clips that hold the fuses. That might solve your problem.Frank Link to comment https://www.classiczcars.com/topic/30441-lights-out/#findComment-270490 Share on other sites More sharing options...
240jetjoc Posted January 7, 2009 Share #3 Posted January 7, 2009 I had the same problem with my 1972. The fuse looked great, but it was bad. Link to comment https://www.classiczcars.com/topic/30441-lights-out/#findComment-270492 Share on other sites More sharing options...
Zs-ondabrain Posted January 7, 2009 Share #4 Posted January 7, 2009 (edited) Start checking all your grounds. And check the connections at the switches, in the steering column area. The headlights and parking lights are 2 seperate systems so that tells me it's a supply or ground issue.Dave.One other thing, your post will be read. but it's not a good idea to ask the same question in multiple threads. Just FYI. Edited January 7, 2009 by Zs-ondabrain Link to comment https://www.classiczcars.com/topic/30441-lights-out/#findComment-270498 Share on other sites More sharing options...
refman1970 Posted January 7, 2009 Author Share #5 Posted January 7, 2009 Thanks for all your advice I'll try it Link to comment https://www.classiczcars.com/topic/30441-lights-out/#findComment-270588 Share on other sites More sharing options...
260zCaliCar Posted January 8, 2009 Share #6 Posted January 8, 2009 Just clean the clip and replace the fuse (make sure that you do the right one) it's just to easy to do not to try it. If the other lights did work, and now they don't (for no apparent reason). I'd bet on the fuses. It was my problem (it was actually just so dirty it lost continuity)... Before I replaced the fuse, I'm not so happy to say that I must have traced every wire/ground/ connector in the entire car. My wiring is great now! Link to comment https://www.classiczcars.com/topic/30441-lights-out/#findComment-270607 Share on other sites More sharing options...
