Has anyone taken apart reclining seat hinge (spring side!)
I was curious if anyone has ever taken apart (or heard of someone taking apart) the hinge mechanism (reclining style) on the inside?
There exists a large spring inside that mechanism that serves to pop the seat forward when pull the side lever. It is a very strong spring wound into a coil. When the center pivot pin is removed the diameter of that spring is increase. But I have no idea by how much.
I plan to use a wide hose clamp (and a blast shield) around the hinge body and the spring when I remove the pivot pin. Then I will slowly open the wide hose clamp.
Assembly should be the reverse of disassembly, but if the unladen spring diameter is too large I can foresee difficulties.
I was hoping someone had disassembled one of these springs and might share insight. My reason is to be able to powder coat the spring housing completely, and I am fully aware that I am being really anal. I did decide against removing the seat frame (under butt) springs for lack of desire to find or make a crimping too to cleanly crimp them back on.
Thanks,
Jeff
Hey Garagegoon,
You don't have to take one of yours apart. I asked my boss and we ended up taking mine apart.
It comes apart very easily, and looks like it will go back together just as easily.
Thanks,
  • 3 years later...
