I just completed my SU converson on my 1975 280Z. I have the 3 screw round tops and could use some advise
Upon starting the car, I find that the front three cylinders (Front Carb) are not working in that when I pull the plug wire out, the engine continues to idle without stumbling. When I pull the plug wire out for the other 3 cylinders, the engine stumbles.
When I spray carb cleaner in the front carb, the engine begins to idle normal.
When I push the piston up in the front carb, the engine does not die. When I push the piston up in the rear carb, the engine stumbles or dies.
When I push the choke for the front carb, the engine idle picks up.
The mixture nut on the nozzle is out 2 1/2 turns on both carbs.
Whats my problem.?
Can i switch the nozzles between carbs to see if the problem persists?
Lean mixture in front carb?
not sure here... Any assistance will be appreciated. Thanks.
2 fast 2 Z.. I will recheck but it should be 12mm for rear and 16mm for front for a 3 screw carb..
sblake01.. Respectfully, I know you are a proponent of EFI systems and there will always be discussions/arguments over which is better but your comment above does not help me..
Will it run on all 6 other than at idle? That's one lean carb, partially plugged up maybe. Won't run on all 6 at all. No fuel to the carb or something in the carb completely plugged up.
Steve
How do I test to see if all six runs when not idling? Do I rev up the engine and have someone pull the plug wires to see effect? sorry, just trying to clarify..
I had taken apart the carb and cleaned it, blew compressed air in all passages.
I think you can tell the difference between the power of a 6 cylinder engine vs. a 3 cylinder engine. Take it out and drive it.
Steve
Shadesh, i don't know the measurement for 3 screw carbs, but where dit you get those measurements?, common sense to me would be that there have to be the same front and rear, i just looked at my FSM and the 4 screws have to be 14-15 mm. front / rear.
Chris
Chris
Chris,
See the attachement.. I dont really understand why the measurements would be different for a 3 screw vs 4 screw but here it is...
Maybe the float bowls sits in different hights, still i think it is a adjustment problem, SU's are simple carbs and it seems that your front one is starving, so if there is no gasket leaks, i still vote for incorrect float hight..
Do you understand the SU function?
EFI the bastard:eek:
Chris
I apologize for throwing in that rather moot comment. It was meant to be tonge-in-cheek not derisive. Actually, I'm only a proponent of EFI systems on vehicles that were originally equipped with it. Do you have access to a tool like a Uni-syn or Color Tune? I've used both of those in the past to assist in balancing carbs.
  • Who's Online   2 Members, 0 Anonymous, 1,256 Guests (See full list)
