MaximaCatt Posted September 21, 2002 Share #1 Posted September 21, 2002 I really need to know the measurements of the lug nuts on the 1973 240Z car.Thanks for your help.Jeff catt Link to comment https://www.classiczcars.com/topic/3080-1973-datsun-lug-sizeing-question/ Share on other sites More sharing options...
2ManyZs Posted September 21, 2002 Share #2 Posted September 21, 2002 The stud size(diameter) is 1.25mm if that is what you are asking. Link to comment https://www.classiczcars.com/topic/3080-1973-datsun-lug-sizeing-question/#findComment-16041 Share on other sites More sharing options...
MaximaCatt Posted September 21, 2002 Author Share #3 Posted September 21, 2002 Well I guess I ment the bolt pattern, is it the same as honda's. Link to comment https://www.classiczcars.com/topic/3080-1973-datsun-lug-sizeing-question/#findComment-16045 Share on other sites More sharing options...
2ManyZs Posted September 21, 2002 Share #4 Posted September 21, 2002 I think the Honda lug pattern is 114mm, where the Datsun is 114.5mm, close but not quite. Link to comment https://www.classiczcars.com/topic/3080-1973-datsun-lug-sizeing-question/#findComment-16049 Share on other sites More sharing options...
MaximaCatt Posted September 21, 2002 Author Share #5 Posted September 21, 2002 Dang it, well thanks for your help. Link to comment https://www.classiczcars.com/topic/3080-1973-datsun-lug-sizeing-question/#findComment-16050 Share on other sites More sharing options...
Birkl Posted October 7, 2002 Share #6 Posted October 7, 2002 Hi!Datsun, Nissan, Toyota, Honda, Mitsubishi has 4,5" /4 and that is the same as 114,3mm /4 boltpattern. Volvo V40 and S40 has 114,3mm /4 as well.But check the center hole diameter, it's not the same...for example an old Toyota wheel has a smaller diameter then a 240z. Henrik Link to comment https://www.classiczcars.com/topic/3080-1973-datsun-lug-sizeing-question/#findComment-16766 Share on other sites More sharing options...
EScanlon Posted October 7, 2002 Share #7 Posted October 7, 2002 Whoa! 1.25mm for a diameter would be .0049" and NOT what you are looking for. The 1.25 refers to the PITCH of the thread, or if I recall right that it will move out 1.25mm for every full turn of the Nut. (Please correct me if I'm wrong!)The Lug Nut Dimensions are as follows:Diameter: 12mm (or 1.2cm or .4724")Thread Pitch: 1.25RHNot sure on the measurement for center to center, (can't find in my books yet) or diagonal.Hope this helps. Link to comment https://www.classiczcars.com/topic/3080-1973-datsun-lug-sizeing-question/#findComment-16800 Share on other sites More sharing options...
