Yet another pipe diameter Q
Absolutely not.
Do not overestimate how much air you actually need for a mostly stock Z car. I am currently running an MSA header with a 2.5" outlet, that stays 2.5" all the way until the rear suspension, then necks down to 2.0" so it can go to my ANSA. I can promise you, I would not pick up any power at all from replacing my 3 feet of 2.0" pipe with 2.5" pipe.
By the time the gas reaches the rear of the car, the gas has cooled significantly, and thus has a lower volume given the same mass than when it comes out of the cylinder. So going to a smaller tubing toward the rear of the car would probably actually help keep the velocity of the gas up without effecting back pressure.
  • Who's Online   1 Member, 0 Anonymous, 1,503 Guests (See full list)
