It's like a CNC machine with the scanner piece built in.
I don't know why you wouldn't make that part out of a billet, but perhaps for authenticity or something...
Actually they're two separate systems. And the 3-D printers have the ability to form complex, moving, internal pieces which you can't do from a block of billet. The machine works like a 3 dimensional inkjet printer and like they said can use dissolvable materials in place of the plastic to create internal parts.
If you want a part you can actually use instead of just look at then the 3D printer isn't too useful. Using the output of the printer to create molds so you can cast parts in higher strength materials is about as good as it gets. There are some that print parts in sintered metal that can baked into fairly strong parts but it's still not a substitute for the original material if you are trying to duplicate an existing metal part. They are getting better every day but still a long way from spitting out exact duplicates as far as strength is concerned.
Steve
If you want a part you can actually use instead of just look at then the 3D printer isn't too useful.They are getting better every day but still a long way from spitting out exact duplicates as far as strength is concerned.
You're right. The end result is a part which is composed of very small orbs or strings (depending on the printer) of plastic (the plastic is usually ABS). This means they're typically not very strong and are best used in forming a mold to cast new pieces.
That is ridiculously cool. I'm amazed at both the price and size of the scanner, and incredibly amazed that the "printer" can out complex moving parts like that working steam engine replica and what appeared to be a pre-assembled diff.
Couldn't you just take the configuration of the old part, i.e. dimensions, etc., that are generated by the scanner into the computer program and go directly to the cnc machine process without having to make a model on the 'printer'?
The NextEngine Scanner is a nice portable solution. I found it couldn't capture the detail needed for a couple of projects I've done. I would suggest these guys if you're serious about scanning and need finer resolution or even IGES data of that scan:
http://www.directdimensions.com/
I've had great success with them - their expertise in the field is great.
For these types of parts, printing quickcast is the way to go - that is, if you intend to go down the road of investment casting. Or make rubber molds from straight-up 3D printed parts (preferably Objet or SLA).
BTW - if anyone has any SolidWorks needs, feel free to PM me. It's what I do for a living (legally own a license, Design Consultant, Certified SolidWorks Professional, teach SolidWorks at a couple of local design colleges, yada yada).
Cheers,
Colin
The printer might be more to impress people with vast amounts of money and the willingness to spend tens of thousands of dollars on a single part (read: Jay Leno).
Just so we don't assign somewhat misleading uses and motives to the equipment itself - the fact that one could use it for the auto hobby, doesn't mean it was intended for the rich and famous. Nor should we expect it to stay as expensive in the future.
Building design and engineering prototypes has always been a very useful and in many cases necessary process. One that has always been time consuming in both actual work hours and more importantly total project schedule...
Being able to scan existing components, to rapidly build a 3D data base that can be modified to reflect design changes, or altered into completely new products can save a lot of time and money in the product development cycles. It can also cut the time needed for all manor of engineering analysis model builds, to feed simulations etc etc.
Likewise "printing" a prototype part in hours presents the potential to save hundreds of thousands of dollars in prototype build costs, and reduce schedules from weeks to hours. Building them in plastic, on the spot in the engineers office, and providing the ability to support many iterative changes/improvements etc - is amazingly cost effective.
This "stuff" didn't start out being equipment for Jay's Garage... it's just that with the constant advancement of the technology - it has now made it inexpensive enough to find thousands of other uses in every day life.
Compared to the 50's and 60's - most of us have super computers sitting on our desks today..
FWIW,
Carl B.
This "stuff" didn't start out being equipment for Jay's Garage... Carl B.
Oh for sure, I know that, obviously. Where I was going with my comment was that for a "Solution to NLA Parts" ... and the examples that Jay was frothing at the mouth about, the printer isn't as useful as the scanner. If you're making prototypes or test fitting one-offs, then the printer would be invaluable.
Gotta love this one, too.... http://www.engadget.com/2007/05/10/diy-3d-printer-utilizes-hot-air-sugar-to-craft-random-objects/
Ok guys I found it!!!! Forget the $3000.00 3D scanner. How about $30.00 for one? Now put this with candy fab and we got a fun toy.
<embed type="application/x-shockwave-flash" src="http://revision3.com/player-v1940" allowfullscreen="true" width="555" height="312" />
Edited by carguyinok
  • Who's Online   1 Member, 0 Anonymous, 286 Guests (See full list)
