I have question as long as we are on this subject. Is there a problem if you use a four screw spacer on a three screw manifold? Will this block the coolant from travel on through the manifold since it is not circulating through the carbs?
Gary
Gary,
Maybe we can enlist the aid of someone with a 3 screw manifold half lying around. If somone has one and wouldn't mind helping with this "Watch Mr. Wizard" experiment, plug the holes into the carb base and blow into the water inlet or outlet hole and see if air comes out the hole on the other side.
I looked into this issue early in the life of my former yellow Z. IIRC, the square spacers for 4 screw carbs do not cover the coolant passages in the manifolds. So the 4 screw spacers will only work if the coolant plumbing has been bypassed.
Gary,
The answer is no. I have 3 screw carbs with an E88 manifold. I stuck a drill into the manifold waterline from the thermostat side and it does not go past the first inlet to the carb so the water will in fact be blocked from that point on. I have seen debates on both sides as to whether we actually need to run water through the intake manifold, I guess it's personnel preference. I don't have any reasons not to run water through mine so I will keep mine operational.
Mike
I am going to price materials the coming week and mill up a couple sets of spacers. Should take a week or two. Since mine will not be running for the next year or so anyone want to volunteer to try out the first set?
So I'd surmise that if you wanted to run water through the manifold while blocking off water to the carbs, you could drill through that wall between the 2 passages to the carb base. I'm guessing drilling in one side and out the other was what was done to get water through the 4 screw manifold. We will look at some manifolds and confirm.....
I would agree with that Bruce. You could also mill a slot between the two holes on the gasket surface.
Not everyone here can just arbitrarily set-up and "mill" something like you can Mike. Nyuck nyuck.....
Most everyone has a drill...... Everybody here with a mill hold your hand up.
Another FWIW. There is a freeze plug on the 4 screw manifold half underneath and two on the screw manifold half which open into little water holding chambers in the maniflold. The reason for the 2 cavities on the 3 screw is because of the interior seperator wall inside.
pARANOIAWILLDESTROYA!
Arne, at least I didn't mention selling cars you don't own on a website you do!
Just seeing if you were paying attention!
Will
Not only paying attention, I've got a memory... LOL
Arne-
You have a "get out of 'Found my car in a Hot Wheels package' Hell free card'! The rest of yu rabblerousers-well...
Now at least one of those Hotwheels/used car site jokesters in Oregon has a clean slate!
Will
This site has spacers available in multiple sizes.
http://www.aptfast.com/Images_Parts/SU/SHIF44-05.jpg
http://www.aptfast.com/APT_Parts/SU_Parts/a_SU_components.htm
Not sure exactly what size early z's use but if they are selling for $10.99 it would take a long time to recoup costs of reproduction. They also have just about everything else for SU's but they specialize in MG's. Just my opinion.
If you know the correct size of everything you need you should be able to find it here.
John
  • Who's Online   2 Members, 0 Anonymous, 1,453 Guests (See full list)
