The sleeves are not the same OD as the strut tubes. 240Z strut tubes are 2.005" OD and 260/280Z strut tubes are 2.15" OD. Typical threaded collars are 2.39" OD.
Also, there's not enough wall thickness in the strut tube to accommodate the 70% thread you'll need for a custom spring perch. You can cut off the strut tubes and weld a threaded shock tube in its place, which is what I did when I ran Penskes on my 240Z.
https://www.classiczcars.com/topic/31142-strut-housings/#findComment-277447
  • Who's Online   2 Members, 0 Anonymous, 1,167 Guests (See full list)
