Will a 280 dash bolt into a 240? I have searched but not found any info. I know the wiring is different and the heater controls are different also. I have a complete 280 dash without cracks and I would like to see if I cna swap it for my cracked 240 dash. I have both the console and the dash. Has anyone done this swap?
https://www.classiczcars.com/topic/31199-240-vs-280-dash/
I've seen it done. Usually done because the 280Z dash is deeper than the 240Z dash, so the 280Z dash has room for the factory A/C. Of course you have to also change the center console to mate up with the dash.
It's a good swap if you want good A/C and don't care about keeping the 240Z original.
FWIW,
Carl B.
https://www.classiczcars.com/topic/31199-240-vs-280-dash/#findComment-277861
