I've had good luck using dental floss or fine string. Fishing line would probably work, too. Just go slow, a little at a time, working from both ends and then by "threading" the string through top to bottom under the slightly raised emblem, closer to the middle and pulling "out" between the pegs. It's generally been easier than it sounds.
Dennis
