Site Updates this Weekend ×
Hello guys.
I have searched ,and didn't found the info i need about a '79 280zx manual flywheel.
I am currently rebuilding my Zx and looking at a used flywheel as i can't afford a new one .
Mine is now missing a few teeths,because of a faulty starter,but she stills on the car.
I got a guy near me that got a Bunch of z and zx parts but he don't remember which part goes on which car....
So i whould need to know what is the diameter and how much teeths a '79 l28e manual flywheel have.
if you had a pic of it it whould be awsome
and if you have any other idea how i could know if it's the right one for my car,dont hesitate.
Thanks a lot.
https://www.classiczcars.com/topic/31334-280zx-flywheel-info-needed/
Right,
But right now the car sits in my parking lot.Which is made of Gravel and got a nice inclination. No garage :(
this summer i will be able to give her a better place...
This is why i asked about the specs.
Anyway thanks SBlake01
if someone can give me those infos,you whould help me a lot
Hello guys.
Thanks a lot.
302 mm diameter, 120 teeth.
As far as I know - all 280Z, 280ZX flywheels are the same. The exceptions are the 2+2 and Turbo's. Likewise the starters are interchangable.
As I recall - the 240/260Z's are the same as the 280Z/280ZX flywheels... The clutch pressure plates and disc are interchangable as well - same exceptions for the 2+2's and Turbo.'s.
FWIW,
Carl B.
I found my spare and measured it and came up with basically the same measurements as did Nigel1943. Mine is a 2+2 flywheel. The outer diameter and number of teeth are the same. Where they are different is in the friction area. 225mm for the standard and 243mm for the 2+2/turbo.
I got some News.
The guy found a 302 top-of-teeth to top-of-teeth diameter w/ 120 teeths.
he said that ''E30'' is written on it....
what does it means if it means something ?
I went to my local Nissan dealer.
A brand new flywheel is 400 canadian $
A ring gear alone is 120 Can $
Now i just need to figure out what is the best option
-a new ring gear ,rust-free,with a little warranty(if it dont fit i go back there...) =120 $
- a surface rusted flywheel that might not be the right one ,with shipping($$) =depend how much he sells it ,if he tells me one day (...)
both will need to be resurfaced anyway
Thank you for your help ,
  • Who's Online   0 Members, 0 Anonymous, 903 Guests (See full list)
