I was trying to locate the source of an annoying imbalance in my carbs and found the problem. For reasons I do not understand, one of my nozzles was " customized " by shortening it 1/4".
Does anyone have or know where I can purchase one factory spec nozzle, new or good used, for a REASONABLE price ?
The carbs are in excellent shape otherwise, and appear to be original to the car. They have three screws holding down the vacuum chamber, and the float bowls have a drain plug. The entire engine is completely stock. The car itself has a late 1972 build date.
Thank you in advance;
Ted.
https://www.classiczcars.com/topic/31390-su-carb-nozzle/
I would consider the core worthless since the brass jet has been epoxied into the plastic base.
I am really just looking to replace the one nozzle with a good, used unit as everything else is really in quite remarkable condition. If it ain't broke...
Thanks;
Ted.
https://www.classiczcars.com/topic/31390-su-carb-nozzle/#findComment-279660
  • Who's Online   1 Member, 0 Anonymous, 1,537 Guests (See full list)
