After 2 yrs of putting all other projects ahead of my own, I've finally began to assemble my engine.
I started with a JCR Supercharger setup I purchased from 1TuffZ. In working out the plans for my setup, I came to the conclusion that i wanted to use the best of today's technology in the build. So this ment alot of special, and custom items were going to be needed.......So below is what I have done so far.
Custom SC Cam grind from with Paul Rushman's help, via Rebello Racing.
Kameari Twin Gear Timing kit.
Custom JDM Tensioner ( kameari Twin Gear setup. )
Kameari 1.0mm Headgasket
Kameari ReInforced Engine mounts
Kameari Fully Adj. Cam Gear
Kameari Valve Cover
Kameari (Mech. ) Oil pressure gauge
JDM Valve Cover Studs
JCR Modified Intake for Port Injection & Manifold Intake Air Sensor
CNC Injector holders
Individual Steel Braided lines to each Injector
440cc Injectors
Modified TB from a Mustang *( 7th Injector to cool/Lubricate SC. )
WOLF3D -Engine Management System ( via Ron Tyler )
J & S Safegaurd System ( Individual Cyl. Knock control System )
Individual Coilpack setup ( via Ron Tyler )
Modified Infrared 300zx Dist. ( via Ron Tyler )
Oil cooler setup ( not installed yet )
Ceramic Heated ( not installed yet )
JDM Oil Temp Sensor
Today I started to assemble and test fit things. It's been to long not playing with my own toy's!!...... With any luck, I may actually get it on the road this summer
https://www.classiczcars.com/topic/31436-finally-getting-started/
  • 5 months later...
