Title says it all, I have in the last 5 years of my Z being apart misplaced the Spacer that goes between the wheel bearings in the rear strut housing. I know the dealer no longer has them available. I need 2 with the copper crush washers, if you have them let me know.. I am waiting in these to get the car on the ground.
If nobody has them and are willing to part with them could you mic the ones you have so I can get a set machined..They will have a "B" stamped on them, they were either "A" "B" or "C"..I need the "B".
Thanks,
Jeff
https://www.classiczcars.com/topic/31570-stub-axle-b-spacers-needed/
If you look on the barrel of the strut housing the round part where the stub axle goes through the housing there is a letter stamped. It is either a "A" "B" or "C". the spacer is used for variances when the housings are manufactured and machined to correctly space the wheel bearings when torque is applied for preload.
Hope that helps.
Jeff
