Hi guys.
I did something really silly to my K, and now I need to fix it. does anyone have 2 rear guards for a coupe? doesn't matter if they're rusty. preferably in SE Qld, but I'll freight them if I need to.
A whole car or shell would be OK too. (actually preferable, because I need the bar with the shock mounts and the rear diff mounts as well.
any help greatly appreciated.
cheers,
Matt.
https://www.classiczcars.com/topic/31825-rear-guards-for-a-coupe-wanted/
Took a jump at about 140kmh. when we landed, it just turned right. bounced off an embankment, then slid sideways into the poles of a cattle grid.
Still don't know if something broke, but whatever happened, it happened fast. best ride in the park for about 100 metres. And quite a lot of damage as you might imagine.
From this perfect 3 point landing...
To this...
:cry::cry::cry:
Musta been that cheap, nasty suspension you were running, hey MAtt;)
well, its cheap, NOW. :tapemouth
DING!!! :bulb: I've just worked out that 440K is Warps. Who knew? (I don't get out much)
here's where we went in:
there's where we came back out....
here's the cattle grid I tried to get it through.....
failed....:(see where the pole ended up....
and here's where we ended up.
perhaps if I pick up enough pieces I can build a K from it. (that used to be a rear disc.
So if anyone has some rear quarters, i promise to look after them better than this. :stupid:
Edited by matt240K
Really? Are the MCA bits salvageable?
Yes, one and the same. In a former life I owned a 240k "project car". It had a P76 4.4 V8 in it, and sat in my shed for about 2 years before I saw the light and sold it. Last I heard the new owner was fitting an LS1 and going drag racing
yes. need new shafts though.
I knew I liked the cut of Warps' Jyb. Its because you're of good stock. :cool:LOL
  • Who's Online   1 Member, 0 Anonymous, 1,534 Guests (See full list)
