KID-K Posted May 21, 2009 Author Share #13 Posted May 21, 2009 Hello Mr Vert... .I hope this helps. My rear guards are pretty much the same as the you would do the front guards if they were made from one skin. If you look up into the rear guard, my inside flare is as high as the inner skin, in the photo you can see the original join from the two sections. In comparison to your photo I think I positioned my flare lower than yours, I did this to get rid of the jet hopper look..The second photo shows where my inner guard starts. Basically the area you have between your top flare hole and your bottom lip is part of my inner flare only beaten up for clearance...I've also included a photo of flare position. In the last photo the wheel is sitting on the bump stops (No spring), it actually just touches on the left side of the flare (because my camber and toe adjustments are all loose) and the wheel still has enough clearance to roll. Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-284299 Share on other sites More sharing options...
ovenfood Posted May 23, 2009 Share #14 Posted May 23, 2009 wow i always wanted my car to go that way but i feel ive had to many build restrictions on this build but now that you have done it i dont need to :> thanks its really a very nice build :> Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-284523 Share on other sites More sharing options...
KID-K Posted May 25, 2009 Author Share #15 Posted May 25, 2009 Found some shots of the flaring process..my brother had them on his phone!!! Don't laugh at the green!!!! Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-284685 Share on other sites More sharing options...
KID-K Posted May 25, 2009 Author Share #16 Posted May 25, 2009 Started putting the arse end together over the weekend, just waiting for some shocks and springs then i can put the cv's and sway bar in......... Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-284686 Share on other sites More sharing options...
KID-K Posted June 1, 2009 Author Share #17 Posted June 1, 2009 Got the car blocked back and undercoated, just some shots..........Paint it black? Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-285327 Share on other sites More sharing options...
240K&Beyond Posted June 1, 2009 Share #18 Posted June 1, 2009 Hum, two more coats, then a light saturn red pearl clear over the top. I cannot say how much I appreciate the pictures and how much I miss my workshop. Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-285332 Share on other sites More sharing options...
minimafia Posted June 2, 2009 Share #19 Posted June 2, 2009 Keep up the great work mate, loving this build. thumbs up!!!!!! Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-285437 Share on other sites More sharing options...
Tyrone Posted June 2, 2009 Share #20 Posted June 2, 2009 If you leave it flat black with the polished trim, I'm gonna have to get my cough medicine. The car will just be so sick!! I think you should leave it Black. The trim would go good with the rims too. Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-285445 Share on other sites More sharing options...
bonzelite Posted June 5, 2009 Share #21 Posted June 5, 2009 tops+100 Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-285716 Share on other sites More sharing options...
KID-K Posted June 7, 2009 Author Share #22 Posted June 7, 2009 Got a new parts car last week...looks like it sat at the bottom of the sea for awhile...:sick: Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-286024 Share on other sites More sharing options...
KID-K Posted June 8, 2009 Author Share #23 Posted June 8, 2009 Some shots of the new 17 inch G-max's and the 4 door.. Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-286025 Share on other sites More sharing options...
khughes Posted June 8, 2009 Share #24 Posted June 8, 2009 Hi Mate,awesome work there.. you are certainly ploughing through it! Link to comment https://www.classiczcars.com/topic/31880-operation-240k/?page=2#findComment-286069 Share on other sites More sharing options...
