While not new to cars buy any means i am new to the 240z. Picked up a fine example.
Runs a little rough but still drives pretty good.
My carbs are out of sync i can tell. REal rich smell and fumes coming from pipe. Sometimes even black.
I am coming from the rx world and a rotary guru and am excellent with other makes and models. I worked at ford for 12 years as a mechanic. Its just been so long since i have monkeyed with side draft etc etc.
I got them going pretty good lock nuts underneith 3 turns out idle set via two screws at 850. runs pretty good. Backfires threw carb if i stab it over 1/2 or 3/4
Guesiing timing is off or i am running lean up top. any help would be great.
Bienvenue! Welcome.
You need level tube to balance the carbs, real useful...
Good evening. Send me an email and I will send you 24 pages on how to tune the SUs. A little documents I have found on the web.
May be helpful to you
And this also:
http://www.jetlink.net/~okayfine/sutech.html
Hi Ben:
Welcome to the group and the Classic Z Car world. Lots of helpful people here and I'm sure you will enjoy your experience with the 240-Z.
12 years with Ford... hummm... I may have to pick your brain. I have a 91 Super Coupe with 9K miles - and the Radio (Boise Sound System) and Odometer both stopped working at the same time. Really odd... but so far I haven't found anything that ties them together... Maybe an off-line discussion there...
Post some pictures of your Z when you get a chance and fill in a little more details... mileage etc. That would give us a better over-all idea of the condition of the S.U.'s and the distributor... Should we guess that the original Flat Top's have been replaced with the earlier S.U.'s??
FWIW,
Carl B.
