I have a '72 with a very rough ride. It just does not make for a very pleasent drive, especially for the wife, when the car seems to take every bump as a major parking lot speed bump. All bushings had been replaced with a Susp. Tech. urethane kit and Tokico springs/shocks/struts within the last few years. Tires are Goodrich 14" T/A's. What first could be done (or at least looked at) to try and soften the stiff ride?
https://www.classiczcars.com/topic/32053-very-stiff-ride/
I did the tokico "upgrade", and am not happy with the ride, way too stiff and jittery for a daily driver, although ti does handle great, and looks great. It almost feels like the car is shaking itself apart on bumpy roads. I am going to put the stock springs back in and see how much that helps. Some mods are best left for the track or show cars.
my 2 cents
https://www.classiczcars.com/topic/32053-very-stiff-ride/#findComment-285566
One mans ride is another mans backache...
My '72 sits on coil-over struts w/Tokico HTS and 275lb springs, poly bushings, larger sway bars and a heim joint TC rod. It is driven on bumpy New England roads with 2 degrees of negative camber, 4 degrees of front caster and sits at 6-inches @ rockers.
Is it stiff? You bet. Do I sometimes think to soften it up? Yes. Have I ever done so? No.
Does my wife ride in my Z? No. Would she if I changed the suspension? Maybe. But first I'd have to install a different exhaust.
Set your suspension up to where it makes you happy and then enjoy......
https://www.classiczcars.com/topic/32053-very-stiff-ride/#findComment-285567
So very true. :D I have ruined the ride on many cars over my three+ decades of car ownership. But since I don't track or auto-x my cars anymore, I have been staying much closer to stock these days. I get my handling improvements mostly with tires now, and leave suspensions mostly stock. The Z actually has more suspension mods than any of my current vehicles now, and the mods consist of KYB shocks and cut-down Euro Stage 1 springs. Pretty mild. But it works for my purposes.
https://www.classiczcars.com/topic/32053-very-stiff-ride/#findComment-285578
I forgot to mention the PDK front triangular strut bar and the roll bar/strut bar in the rear. Once on jack stands you can remove one side and the other side stays up on its' own.
That's a sweet looking brace, but it looks like they are no longer being sold. :disappoin
https://www.classiczcars.com/topic/32053-very-stiff-ride/#findComment-285601
  • Who's Online   0 Members, 0 Anonymous, 1,576 Guests (See full list)
